Weights
Old Jan 7, 2011 | 03:06 PM
fierohink's Avatar
Cab Weights
How much does the cab weigh (about) for a 94 standard cab, no power options?
What is the best method for picking up said cab? Four guys in the corners, starps through the roof? Pull the doors or leave the doors on?
Thanks
Old Jan 7, 2011 | 03:19 PM
tumor21's Avatar
i've seen it done with a fork lift before, but that's not something everyone has available of course. If you've got big enough friends that have strong backs, then I guess I would unbolt everything I could, including doors and give it a try.
Old Jan 7, 2011 | 04:41 PM
aquaprice's Avatar
Took one off with the help of 2 other guys. Removed the doors and the seat first. Personally after that I wished I had a forklift.
Old Jan 7, 2011 | 06:04 PM
dropzone's Avatar
Fossilized
Engine hoist with some straps...remove the doors, takes 10 minutes
Old Jan 8, 2011 | 08:32 AM
tried4x2signN's Avatar
From: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
Using the body to lift it can deform it.
I have limited height in my shop and was planning a cab swap... But the rust gods prevailed.
I was gonna remove the cab and place some 4x4's between the frame and cab.
Then, using post ties at Lowes
form a box with shortened sections of 4x4, under the two long ends of the 4x4's that ran under the cab, forming a box.
Then, using a high lift jack and cribbing, lift and crib.
Jacking from the center means you can crib the corners.
All 4 corners means it'll be stable.
18
Sep 21, 2015 06:15 PM
JookUpVandetti
Sep 17, 2015 09:25 PM
Jake28296
Sep 16, 2015 06:10 AM
Dparr2ndgen
Sep 8, 2015 01:06 PM
RobotMoose
Sep 2, 2015 05:53 AM
