which Weber to use on my 87 yota 22r
Old May 21, 2012 | 08:12 PM
chevychevy33's Avatar
which Weber to use on my 87 yota truck swb single cab bobbed rear, 4x4, 22R with RV cam ,5 speed manual , stock tcase, 38.5 bogger (i run low range off road) , flowmaster exhaust , 456 gears locked, long tube header .... what weber would fit me best >>34,36,or38mm or 40mm or.....
Old May 24, 2012 | 12:05 AM
JonnyBoy's Avatar
With 4.56's and 38.5's, I'm gonna say a Holley 4 bbl on a small block v8. You're way under geared for a 22r at that point. The best you could hope for is a 32/36 with a sync-link installed to keep the intake velocity higher than a 38/38 synchronous. Higher intake velocity generally means better low end torque, but I still think you'll be wanting for more power from your engine, not your carb.
1uzRunner
63
Nov 10, 2018 03:58 PM
user 82300
Jan 19, 2016 02:01 PM
shalom
Sep 8, 2015 10:02 PM
Fakayayou
Aug 9, 2015 12:47 AM
priest16
15
Aug 6, 2015 07:43 AM
