Weber Carb Gasket issues.. please help!!!!
Old Nov 13, 2019 | 09:42 AM
Puck's Avatar
I had a gas leak soaking throught the base connector gasket and i ended up buying a new 3236 dgev carb and did not replace the base plate for the manifold. The new carb worked fine with no vacuum/gas leaks for about a month then it all of a sudden srarted leaking gas through the new gasket in the same place it did before. What can i do to permanently fix this issue? When the gas leaks obviously its idling poorly and basically breaks down until it starts again. I need to correct this asap. Thanks for your help. Any suggestions would be great. Truck is sitting there in my garage waiting on me until i can fix this issue and all i want to do is drive it.
Old Nov 14, 2019 | 05:03 PM
superex87's Avatar
Are you using the adapter plates that came with the carb? I tossed those and used a transdapt adapter. Worked way better and no leaks. I did have to make some spacers for the throttle linkage as the adapter raises the carb up about 2 in.
carb adapter carb adapter
Old Nov 15, 2019 | 05:27 AM
Puck's Avatar
Yes i am using the weber mounting plates and gasket
Old Nov 15, 2019 | 05:32 AM
Puck's Avatar
Should i check the float bowl level? Could it be pressure being built up and overflowing and not venting properly? Like i said it ran just fine with the new carb for a month then it just did this again out of nowhere.
Old Nov 15, 2019 | 12:23 PM
Tims86Toy's Avatar
Pictures would help tremendously. Have you checked to make sure the adapter/intake/carburetor isn't warped?
Old Nov 15, 2019 | 12:33 PM
OldBlueMidnight's Avatar
5 Year Member
Are you running a fuel pressure regulator with the 3236? Based on your description of two leaks in the same place despite a new gasket, it sounds like a problem with the gasket surfaces, but I wonder if running the Weber at a higher pressure than it likes could be a contributing factor.
Old Nov 15, 2019 | 12:34 PM
Puck's Avatar
I hope the carb isnt warped its brand new. I have not checked manifold or adapter for warping. When it was put on everything seemed to be as it should, but obviously not. I can take pics and post. Thanks.
Old Nov 15, 2019 | 12:41 PM
Puck's Avatar
I do have a regulator set at 3 psi
Old Nov 15, 2019 | 12:48 PM
Tims86Toy's Avatar
Always check your surfaces with a straight edge. If you can take some pics of the actual spot where it's leaking from and the surfaces if you have it broken apart.
Old Nov 15, 2019 | 12:53 PM
Puck's Avatar
I will take it apart and take those pics. I drove it for a month not a single problem. Then i drove it all day for a few hours one day last week and it ran just fine with no issues. I let it sit for a few hours then i went to start it and pull it in my garage and immediately the idle bogged down severely and thats the moment i noticed gas leaking again through the base gasket.
Old Nov 17, 2019 | 04:53 AM
87yo_ta's Avatar
I had the 32/36 and now have a 38 on my '87 22r. I threw away the two piece garbage that came with the kit and bought a one piece from LCE Perfromace. The Trans-Dapt is a little cheaper and one piece as well. The two piece adapaters are notorious for having leaks. I used Hylomar as a gasket sealent. There are other fuel resistant sealants as well. No problems in 10+ years.
Old Nov 17, 2019 | 12:03 PM
Puck's Avatar
I appreciate the response. I will do the trans adapter and the sealant as well. The help is very much appreciated because it is so hard to get local advice on carburetors
Old Nov 17, 2019 | 12:10 PM
Puck's Avatar
Would this fix my problem????https://www.lceperformance.com/Spira...-p/1033028.htm
Old Nov 17, 2019 | 06:14 PM
superex87's Avatar
Yes that should fix your problem. What type of fuel pressure regulator are you using? I used a Holley regulator and that worked perfectly. I started out with a cheapo round auto store regulator and that thing did not work at all.
Old Nov 18, 2019 | 01:10 AM
87yo_ta's Avatar
That is the adaptor I am using. Very nice quality and works great.
Old Nov 18, 2019 | 03:55 AM
Puck's Avatar
Im using the mr. Gasket regulator at 3psi. I will be purchasing this adapter. Thanks for the help and useful knowledge
Old Nov 18, 2019 | 03:29 PM
87yo_ta's Avatar
Let us know how it all works out.
Old Nov 19, 2019 | 05:33 PM
superex87's Avatar
loose the Mr gasket regulator and get a holly. The Holly will be reliable and accurate. Do you have a gauge on the fuel line to verify your fuel pressure? Webers are know for running bad with too much fuel pressure. The higher pressure will push fuel past the float needle and flood the carb.
Old Nov 20, 2019 | 03:54 AM
Puck's Avatar
Great advice. I appreciate it
Bruinpilot
Feb 21, 2014 06:48 PM
dhall50
Jun 8, 2010 01:38 PM
mcgill617
May 4, 2009 05:34 AM
joshd
Dec 11, 2006 04:04 AM
