webber carb?
webber carb?
i just ordered a cam from lce performance, got the stage 2 street cam and the full cam kit, sence i already have a header /full exhaust would a webber 32/36 carb be alright? also if i get a new carb should i get a new intake mani or can i just reuse the stocker?
you can reuse the stock manifold, the stage 2 came from LCE IMO would be a good match for the 32/36, but I would not have run that in a trail truck as it's a mid-high rpm cam. In a celica yeah, but a 4,000 lb truck that isn't gonna see 60+ in the desert, no.
A Stage 2 cam will give you excellent mid-range power all the way up to around 6,000 RPM. The broad mid range this cam provides makes it an great upgrade for anything from a daily driver up to a rock crawler or even a mild race application.
20R/22R - Stage 2 Camshaft
4WD / Pre-Runner / Hot Street 2WD (1500-5500 rpm)
Modified Carb or Throttle Body & 1 1/2" Header
What really sealed it for me is the fact they told a guy on here that his weber was a fake because the jet kit they sent him didn't fit is manual choke DGV 32/36, when they simply just don't know weber's and the manual choke jets are different then the electric chokes. They probably told him that so he bought a "real" way overpriced weber from their site.
engnbldr for heads and cams, thorley for headers, also NWOR for headers, trail-gear also makes headers theres lots out there. Putney's, many many others you just got to search most of which is on here. Weber kits, you can get them anywhere, I got mine at webercarbsdirect.com. Intakes there is a lot of offenhauser suppliers out there. Summit racing is one of them.
Toys4parts
Sep 26, 2015 01:56 PM
