water too deep
Old Mar 11, 2006 | 08:55 PM
94 sr5's Avatar
Unhappy water too deep
as it says above i went in water that was up over my bumper on the drivers side. now my clutch sounds like it has sand in it and when i start moving from a dead start it sounds like the tires are spinning, could i have gotten mud in the tranny??? Also it wont start up on the first time now I need your help
Old Mar 12, 2006 | 04:29 AM
leebee's Avatar
open your air box and check your air filter to see if its wet. pull your plugs, crank the engine over to expel any water that may be in the cylinders, drain and change your oil and filter.
you will probably have to drop the drive shafts and trans to checkthe condition of the clutch, pilot bearing, shift fork and slave. while you are at it, you might as well pull the wheels and check the brakes and bearings. regrease and replace where necessary, front end, drive shafts etc. open your diff inspection plugs (upper not lower) and check for milky fluid in the diffs. if you dont already have extended diff breathers now would be a good time to do that mod. diff fluid is relatively inexpensive, change it out as well.
welcome to offroad maintenance 101. this list is by no means all inclusive, search on here for other maintenance to perform after spending time in the water.
lee
Old Mar 12, 2006 | 08:33 AM
94 sr5's Avatar
Unhappy
yea I open the air box and this is what I saw
Old Mar 12, 2006 | 08:35 AM
94 sr5's Avatar
forgot to mention the dif never even got to the water, and also i looked at the tranny today and it didnt have much mud on it and after driveing about 1/10 a mile the sound was gone
Old Mar 13, 2006 | 05:59 AM
shiftless89's Avatar
your plugs could be fouled as well.
Old Mar 13, 2006 | 01:14 PM
Elvota's Avatar
Curious as to how you got your bumper to the water line... yet didn't get the diff wet?
Old Mar 13, 2006 | 01:42 PM
94 sr5's Avatar
where I was riding they dig up sand and sell it and he digs "test holes" that are about 4 in diamater and about 3 feet deep. well he had dug this one where it diped down off to the side of the road the "puddle" was only about ten feet long. I drove in about 4 and then my left front droped into the hole which put my front bumper under water and the rear wheels were still on soild ground
Old Mar 13, 2006 | 04:29 PM
94 sr5's Avatar
well i went out today and bought a K&N filter and now it starts up much easier
presto30
Sep 15, 2015 09:41 AM
LotOMiles
Sep 14, 2015 11:45 PM
elaketiger
Sep 14, 2015 09:58 AM
--Oz--
Sep 6, 2015 01:06 AM
