Washed my engine big mistake
Old Apr 6, 2017 | 12:46 PM
atcfixer's Avatar
5 Year Member
Newer truck, but I had a T100 with a bad igniter for the 3.4L engine, would start and die like a bad AFM, long story short it was the igniter not sending the signal back to the ECU that it's sparking/running and ecu stopped pulsing the injectors.
Old Apr 6, 2017 | 01:22 PM
87blyota's Avatar
This is a 22r so it has a carb. https://m.youtube.com/watch?v=i0ZON7H-dVo
here's a video truck pretty much sounds like it has a big cam.
Old Apr 6, 2017 | 03:32 PM
87blyota's Avatar
https://m.youtube.com/watch?v=NEA6zzbTkUI
Old Apr 7, 2017 | 08:41 AM
87blyota's Avatar
problem solved bottom of carb had water sitting in it.
Old Apr 7, 2017 | 08:03 PM
  #25
Neemox's Avatar
Glad to hear you found the problem! I just got a new truck and am thinking of washing the 22RE. Any advice on what not do to? Are there wires I should pull out of the way before going after it with the washer?
Old Apr 8, 2017 | 04:08 AM
  #26
87blyota's Avatar
Honestly I'd say don't do it. But if you do wrap fuse boxes and alternator with bags and wash everything by hand don't use a hose or anything
