Sponsored by: CARiD
Wanting to lift 94 2wd pickup
Old Aug 17, 2009 | 12:12 AM
dsb12's Avatar
Hi everyone'
I have a 94 toyota pickup 2wd 5speed all stock. I dont do any crazy off roading I use it to haul around my dirt bike and some roads get bumpy and to rough for the truck at stock height. My question is all I want is to lift it to about the stock height of what the 4x4 pickups would be. Is there a cheap solution to this? Are any of the stock 4x4 parts compatible? Any thoughts or suggestions u guys have just let me know. thanks guys
Old Aug 17, 2009 | 12:20 AM
1990mudslut's Avatar
The cheapest way is to do a bl It is also the easiest as well.You have a 5 speed so you wont need any extra brackets nor do you have a 4x4 linkage bracket.So I would say a body lift is the best choice you can get them up to 3 inches.http://www.4crawler.com/4x4/ForSale/BodyLiftKit.shtml
Suspension lift should make the truck ride better on bumpy road but if you want to get to the stock 4x4 height I believe you would need a 4 inch lift which is pretty pricey.
just my 2 pennies.
Old Aug 17, 2009 | 05:45 AM
Robert m's Avatar
https://www.yotatech.com/forums/f116...thread-183959/
Old Aug 19, 2009 | 11:55 AM
dsb12's Avatar
Thanks for the replys I'm still not sure which way I wanna go. I got some time though
Old Aug 21, 2009 | 12:54 AM
SLOWBOOST's Avatar
id do 4wd arms up front with spacers and tbars, and spring over in the rear. would net about 4", fairly cheap and easy without having a horrible body lift and you'll also have much greater suspension travel.
Old Aug 21, 2009 | 04:59 AM
Robert m's Avatar
please explain how one could do 4wd arms up front and what they will do once installed?
6th Gear
19
Dec 10, 2019 07:31 AM
live4soccer7
Sep 3, 2015 12:29 PM
Tommy T.
Jul 5, 2015 07:48 AM
Dylan199119
Jun 25, 2015 09:54 PM
