w56 to r151f swap?
Old Mar 12, 2009 | 10:26 AM
Beaniam's Avatar
w56 to r151f swap?
The w56 in my 93 22re has been making various bearing noises for the past couple months so I've been keeping an eye out on trannys that go up for sale around me. Latest is an R151F/forward shift 23 spline tcase combo. However it doesn't come with a bell housing. Will the w56 4cyl bell housing bolt on to this tranny? Any other issues I might run into?
Old Mar 12, 2009 | 10:33 AM
4Crawler's Avatar
You'll need the R151F bell housing as that i the part that adapts the R-series gear box to the 22R block. You'll also need a 23-spline t-case or get yours converted to 23 spline:
- http://www.marlincrawler.com/transfe...ine-input-gear
Old Mar 12, 2009 | 10:43 AM
Beaniam's Avatar
the tcase comes with the tranny so the spline count wouldn't matter. The 4cyl w56 bellhousing won't bolt to the r151f tranny though correct?
Old Mar 12, 2009 | 10:52 AM
4Crawler's Avatar
Correct, the W56 bell housing adapts a W-series gear box to the 22R block. The R151F bell housing is for 22R -> R-series and in case you are wondering, an R150 bell housing will fit the R151 (it is an R-series box) but will only mate to the V6 blocks.
Old Mar 12, 2009 | 11:13 AM
hillbillydeelux's Avatar
i did this swap with my truck not to long ago but i used the r150. you need the r 151 bellhousing and just used the standard clutch kit. i think i also used the original crossmember with the v6 tranny mounts. other than that the slave cylinder bolts right up and the throw out bearing and arm work aswell. its a fun swap and man is it worth it, im going to swap a r151 into my 83 later this week.
Old Mar 12, 2009 | 12:43 PM
annoyingrob's Avatar
Damn you guys snatching up all of the R151s so I can't find them for my truck
So the input shaft on the R151 fits a standard w series clutch?
Old Mar 12, 2009 | 12:45 PM
Beaniam's Avatar
Got it. Just gonna keep my eye out for a w56. Unless I get lucky and find a reasonably priced r151f with the bellhousing.
Old Mar 12, 2009 | 06:26 PM
ffryno13's Avatar
ok so whats the parts list for this swap?
Old Mar 13, 2009 | 09:18 AM
R151 with bellhousing, and transfer case. I believe drive shafts transfer over, and slave cylinder and clutch setup should as well I'm guessing.
Old Mar 13, 2009 | 09:25 AM
4Crawler's Avatar
And also make sure you get the shifter, or at least the shifter base plate for the R151F transmission, since it is different than the one on the W56. As I understand it, the shifter location on the gear box is a little bit different, so you may also need to change the hole in the floor to accommodate the shifter.
Old Mar 13, 2009 | 09:31 AM
Beaniam's Avatar
I'm picking up a w56 tomorrow with transfer case. Going to put 4:7's in it and I'd like to twin stick it as well however I'm a little confused as to which forward shift tcases you can twin stick... W56's that share the shifter plate with the transfer case shifter plate can or cannot be twin sticked?
Old Mar 13, 2009 | 09:43 AM
4Crawler's Avatar
Most of the twin stick kits I have seen are for a top shift case, but there may be some that fit a forward shift case with separate shifter bases for the t-case and tranny.
- http://www.4x4wire.com/toyota/tech/twin_stick/
Basically comes down to the fact Toyota has different shifter base plate dimensions for most every setup.
Nothing stopping you from making something custom for twin stick a case with the combined shifter base plate. I think there was a thread a few years back on the pirate4x4 forum about someone doing something like that.
Or you can convert any forward shift case into a top shift case:
- http://www.4x4wire.com/toyota/tech/topshifter/
Old Mar 13, 2009 | 09:45 AM
the clutch splines do line up every thing works out fine but i suggest getting the clutch kit and fly wheel for a 22rte just because the gripping surface of the clutch is greater. you dont need to do this though i went with the sotck setup as far as a clutch.
no mods needed on the floor the only thing is the stick is angled back further it makes it really nice if you are tall cause the shifter is closer to you.
Old Mar 13, 2009 | 10:17 AM
Skinsfan6's Avatar
The bolt pattern on the driveshaft mounting face is larger on the R151F than a W56. I used the front half of the driveshaft off of my turbo donor pickup with my regular rear half. I can't remember if the front driveshaft patterns are different.
Old Mar 13, 2009 | 10:22 AM
4Crawler's Avatar
Or grab a triple drilled flange from one of the on-line vendors (Marlin, Trail-Gear, Inchworm, etc.) and put that on the back of the t-case, then most every type of shaft will bolt right up:
Old Mar 13, 2009 | 10:59 AM
Beaniam's Avatar
this guys idea is pretty cool, and free
http://www.pirate4x4.com/forum/showthread.php?t=482798 just have to put another hole in the floor and shifter boot.
Old Mar 30, 2010 | 11:24 AM
tried4x2signN's Avatar
From: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
so this means a 3.0 V6 and 20-22 R/E all have the same splines and diameter input shaft...
So one could run a V6 9 1/4" clutch disc if he had a RTE flywheel and was running non turbo...
And one can run a 9 1/4" clutch in ANY 20-22 R/E WITH AN L, W or R series trans, if he had a RTE fly wheel and pressure plate...
Std. 22RE clutch is 8 7/8" BTW...
exporunner
3.4 Swaps
Aug 3, 2015 06:10 PM
RobotMoose
Diesel Swaps
Aug 2, 2015 11:00 PM
GeoRoss
Jul 24, 2015 03:03 PM
shadowbirdie
Jul 21, 2015 10:38 PM
89hilux1
Jul 19, 2015 01:32 AM
