Vance164's New Yota Build up!
#401
But anyways Scotty said Bobby won't warrenty his parts unless you buy his hub gear also and he is specfic if u run on it he won't replace it At least from what I was told where tg doesn't ask questions they will just warrenty it and I haven't heard anything bad about the dirty 30's and I mean if uve seen the testing video they withstand almost 10 thousand ft lbs of torque and they still don't break!
#406
Longfields require the Cromoly hub gear to be run to get the warranty on his shafts. He also limits the tires size to 39.5's.
Trail-Gear Dirty 30s don't care about the hub gear or tire size. If you break one, they will warranty it.
As Vance said, I ran Dirty 30s in my previous 88' 4runner without a single issue. I also currently run Longfields with his hub gears in my Diamond Axles and haven't had an issue with them either.
They are both very high quality products.
#408
#409
Well I pulled my front end apart today and it doesn't look good need a new hub and spindle on top of the birfield
so I had work order me some warn hubs today the low end with plastic instead of brass center any opiinons on this? And tomorrow they'll look into a spindle for me it cheered up the brass insert pretty bad
but oh well at least I know what I get too look forward too by the end of this year I'll have a completely rebuilt front axle lol
#410
You can get the spindle bushings thru toyota, FYI I tore one up when i was IFS (lack of grease after submerging in water to much and not regreasing heh)
I think the bushing was like $40 thru toyota IIRC but i had a spare spindle that i slapped on.
#411
#413
Yay got the bushing out so now just need to order a new one and smooth out a bur with the dremel then that should be good to go get a knuckle rebuild kit and the dirty 30's and call it a victory
#419
Can you find a stock one and put it in? And just take it easy until you get some chromos?
Or???
http://www.marlincrawler.com/axle/fr...ield-27-spline
Or???
