VAFM no resistance on vc-e2
Old Jun 25, 2013 | 08:55 AM
easterly81's Avatar
VAFM no resistance on vc-e2 (confused on pins)
Been having problem with poor fuel economy, hesitation, and bogging down at cold start. Tested the tps today it looked good went to the vafm and everything seemed good until i got to the vc-e2 measurement. is this serviceable or replace? it looks like a fixed resistor on the diagram.
OK now i'm confused which pin are which
Attached Thumbnails VAFM no resistance on vc-e2-capture.jpg   VAFM no resistance on vc-e2-capture2.jpg
Old Jun 25, 2013 | 04:47 PM
scope103's Avatar
According to these folks: http://personal.utulsa.edu/~nathan-b...sm/engine.html there is a different pin-out for the 22re and the 3VZE. Since you've declined to reveal your affiliation, I can't go any farther.
The VAF is not a "serviceable" component, but for the cost of a replacement there's no reason not to try.
Old Jun 25, 2013 | 06:09 PM
easterly81's Avatar
Its a 3.0 and i traced the wires back and figured that thanks. The vc-e2 is fine but the vs-e2 at idle is out of spec. Is this part adjustable with the gear inside the vaf if you pop to top off.
Old Jun 25, 2013 | 09:41 PM
scope103's Avatar
VS-E2 is the "wiper"; it should vary smoothly as you open the flap. The "spec" is the entire range; if it is outside of that spec you probably have a short or open. Adjusting the gear would not affect the range (but it will probably make your truck run badly).
Old Jun 25, 2013 | 11:49 PM
Inu's Avatar
Inu
The ohm reading will jump on the wiper circuit.
http://static.photobucket.com/player...0311131806.mp4
When i tested voltage it went smooth from 4.8 down to.38 v
Longbed 90
Mar 11, 2019 12:38 PM
Gutted91
Sep 23, 2015 06:12 PM
accuracy
Sep 20, 2015 07:44 PM
Boomer8404
Sep 20, 2015 06:15 PM
larrys93pickup
Sep 17, 2015 07:05 PM
