Two more thumbs down for Bosch platinum plugs in a 22RE
Old Sep 18, 2009 | 08:33 AM
wilshire's Avatar
Put them in when I first bought my truck a few months ago.
Motor was pinging a little and running hot even with high octane gas. Idle was decent but a little bit unsteady.
I installed NGK's this week and the pinging seems to be gone (we'll see when I fill up again), it runs cooler, and the idle is rock solid.
Old Sep 18, 2009 | 08:43 AM
99SR5's Avatar
sweet good stuff
Old Sep 18, 2009 | 08:53 AM
tc's Avatar
tc
Which NGK - normal, iridium?
Old Sep 18, 2009 | 08:59 AM
wilshire's Avatar
Regular.
Old Sep 18, 2009 | 09:13 AM
ovrrdrive's Avatar
I ran Bosch Platinums for 13 years and about 190k miles with no issues at all. I had a pinging problem that several people blamed on them so I finally put some NGK's in it and it didn't run or sound any different at all. It finally quit pinging when I replaced the rad, tstat and water pump.
Old Sep 18, 2009 | 10:13 AM
89934runr's Avatar
plugs?
Those problems can hardly be traced to the plugs, unless you've gapped them wrong, or are using the improper heat range. There are too many other factors to simply call them out as the culprit.
Have you taken intop account the weather has started to cool off in most areas? That could be the reason you're not feeling the heat anymore.
Old Sep 18, 2009 | 11:21 PM
peow130's Avatar
I run bosch Platinum 2's and actually noticed a little bit of a performance gain.
However, my valves being so far out of adjustment robbed all my HP and Torque
Old Sep 19, 2009 | 01:09 AM
Elton's Avatar
rule of thumb for toyota's do not use bosch anything for the motor along with fram
Old Sep 19, 2009 | 01:55 AM
wyoming9's Avatar
Red face
I only run the regular NGK plugs I see no reason to run a platinum plug in these engines about like running 93 octane in a normal compression engine like 8.5 or 9 to one .
I see nothing wrong with doing it if you think it helps
Old Sep 19, 2009 | 12:29 PM
peow130's Avatar
Hey, i'm not gonna stop using my bosch platinum's just because it's some "rule of thumb"
i've had nothing but good things come from using these plugs.
Better power, a little bit better MPG, etc etc.
Old Sep 19, 2009 | 01:17 PM
showland's Avatar
yall run what you want to but I know that the ngk v power 1.59 cent plug can support over 600 hp with the right heat range and proper gap....I have seen it in a honda motor that I built....platinum and iridium plugs.....biggest waste of money to hit the market yet....
MO transplant
Apr 23, 2023 11:58 AM
Doug4320
Mar 24, 2018 10:11 PM
montanatruck
Feb 26, 2017 07:07 AM
kcaudill
Jul 20, 2015 12:06 PM
bryan34w
Jul 6, 2015 05:53 PM
