Turbo 4runner 5speed swap
Old May 19, 2008 | 07:49 PM
SpecialScottie's Avatar
Has anyone swapped in a 5 speed into a turbo 4runner?
Im gathering a list as to what I need. Any help is much appreciated.
Old May 19, 2008 | 08:55 PM
Anyone?
Old May 19, 2008 | 09:58 PM
89silverpu's Avatar
I thought I read there was a problem with that swap becuase you won't find a 22rte ecu for a manual cause they never made manuals for the turbo...
Old May 19, 2008 | 10:14 PM
hillbillydeelux's Avatar
you just need clutch kit and a tranny preferably a toyota r151 tranny (found in turbo pickups) and drivelines might be different as far as the ecu goes im not too sure about that. plus good luck finding a tranny thats good for a reasonable price.
Old May 20, 2008 | 09:09 AM
89silverpu's Avatar
Corrected...
Old May 20, 2008 | 09:24 AM
DeathCougar's Avatar
Originally Posted by 89silverpu
They didn't make manual transmissions for behind the turbo 22re's it was an automatic...so you won't find any stock 5sp for behind a turbo or an ecu for it
That statement is 100% wrong.
I have a 5sp turbo trans in my 87 4Runner, with dual cases. The turbo trans came from an 86 truck, so yes 5sp turbo manual trannys do exist.
What you should have said was "they did not make a Turbo 4Runner with a manual trans from the factory, as all turbo 4runners were automatic"
All he needs is a turbo ecu from a 5sp 86-87 truck. I have one in stock here at Nix99.
Aside from that, he will need the following parts:
-Trans
-Case
-Drivelines
-Clutch pedal bracket
-Clutch master
-clutch slave
-Clutch lines and brackets
-Shifter assy
-Front 1/2 center console
Best way to do it is find a turbo donor truck, but that is almost impossible. the cost vs benefit ratio to switch a 4Runner from auto to manual makes it not worth it.
Old May 20, 2008 | 09:32 AM
89silverpu's Avatar
-Trans
-Case
-Drivelines
-Clutch master
-clutch slave
-Shifter assy
Thanks for correcting me
Old May 20, 2008 | 02:29 PM
Luvmeye22re's Avatar
Our 86 Toyota pickup at my last job had a Turbo and a 5 speed, but I don't think I've ever seen a Turbo 4Runner that had a 5 speed. Then again I've seen all of maybe 3 Turbo 4Runners that I actually got to take a good look at.
Old May 20, 2008 | 02:37 PM
dj86515's Avatar
I have a complete 86 reg cab with 5sp trans, trans case, axles, drive line near I-40 on AZ/NM border. Gave up on the project.
Old May 20, 2008 | 05:33 PM
Thanks for all the help.
Would I be able to use the turbo ECU with the w56 transmission?
Old May 20, 2008 | 05:38 PM
You would need the Turbo trans, the R151F
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
mskalmus
May 28, 2017 07:51 AM
karbin
Jul 5, 2015 11:37 PM
HRDC0R19
Jul 5, 2015 06:43 PM
