truck won't crank over
my truck has been sitting for about a week and I went out to start it and it does not crank. I can hear clicking under the hood like a solenoid but doesn't crank. The battery is fully charged, do these 89 22-re's have a solenoid switch ?
The search button is your friend.
I'll get you started...haha no pun intended. http://personal.utulsa.edu/~nathan-b.../2starterr.pdf If the relay checks out, try giving the starter a whack while turning the key.
is the starter goin out? loose or coroded battery terminals? if it's a starter prob. try turning the key between the run and start posistions 4 or 5 times really fast. that's all i can think of if it's not turning over...
i had to charge a battery last week to get one of my 4runners to start despite the voltage being pretty good. voltage is not a reliable way to check the state of a battery's charge at all. try charging it first and see if that fixes the problem. also these particular starters are prone to needing a moderate whack to remind them to work
finally got a chance to check it out. was gonna check ou the terminals 1st but decided i would try to start it and it fired right up 1st turn of the key. BTW terminals looked goo but cleaned then anyways.
zd92655
Mar 6, 2022 12:58 PM
