Truck will start but quickly stalls..whats the problem?
Old Oct 29, 2012 | 11:25 AM
MUD-LIGHT's Avatar
Sorry haven't been on in awhile. Turns out I pulled a ground! Simple fix. I swear I can't kill this thing "not that I want to" But Jesus LOl.
Old Oct 29, 2012 | 11:36 AM
Aka paco's Avatar
The spot to jump the relay is right under the hood, a small port next to The fuses, look to connect fp to bp I believe..
My problem was similar to yours, it ended up being the fuel pump.
I tested my old fuel pump before buying a new one, I wired it out of the car straight to my battery , it worked but I replaced it anyway cause I already had the bed off and figured preventive maintenance, what do ya know the cranked up and ran great since. Knock on wood..
The whole time I was messing with the afm, correlay, and it ended up being the pump...
My old pump still powered up, guess it was just old and on the way out
Originally Posted by pete c
Had to hacksaw the old fuel filter on one side. The old filter's flow seemed
fine.
Crap.
When I removed the filter, there was pressure. How much, I don't know. Anyway, I
hooked up the new filter and let the output disconnected. It is not building
pressure or flow. No audible sounds from the pump area.
I disconnected the pump wires. I have 5.5 VDC with ignition on. It goes to 9*
volts when turning over.
This has me kinda stumped.
I think the pump is bad, but, I'd rather not spend 130 bucks (price of pump) to
find out.
Is it OK to put 12V straight to the pump at the connector? Is polarity important
for testing it?
Will my charger with a 1.5A output be enough to test the pump?
JF9243176
Oct 8, 2017 04:21 AM
91toybeater
Dec 27, 2015 07:46 PM
bigblue82
10
Jul 6, 2015 08:27 AM
slider417
Jun 22, 2015 10:18 AM
jmc88runner
Jun 18, 2015 03:39 PM
