Truck stalls under high electrical load
Old Jan 17, 2022 | 07:20 AM
COMTB's Avatar
Originally Posted by scope103
Looking at the photo of your old COR, I doubt your problem was ever an issue with electrical loads. That relay was long past end-of-life. But whatever the back-story, I'm glad you fixed it. And thanks for the wrap-up.
Basically -- when I bought the truck it was missing the inner fender liner and the grommet where the hole for the antenna cable was that runs into the pass side wheel well. Moisture was getting in through there and I had to replace other relays located there but the FP always worked so I never thought to pop it open and take a look until this problem started getting really bad. You're definitely right, the fact it was working at all is kind of impressive.
phychotron
Aug 19, 2019 02:32 PM
JohnnyAK
Nov 18, 2017 07:30 PM
Pri$erulz
Dec 18, 2014 10:18 AM
Nuyota
Nov 19, 2013 10:44 PM
4Run_95
Jun 17, 2008 12:27 PM
