Truck overheated what do I need to do now?
Old Mar 19, 2011 | 11:20 AM
MrHunterman12's Avatar
Ok here is the story:
My dad borrowed my truck that had been running great with no problems but had been sitting for a couple of months. He ran it down to the store the other day and it overheated on him (about 3/4 on the gauge) and he stopped right away. He then checked the radiator level and it was way-way low. He filled it up and let it cool back down and drove it back and it is now sitting.
What is the process I need to take in order to make sure everything is ok?
Thanks guys
Old Mar 19, 2011 | 11:59 AM
justin_4runner's Avatar
1 dont let dad drive it again.
2 check oil that u dont have water in it
3 check water in radiator
4 run truck and burp system to make sure all air is out.
5 drive truck and see if it goes hot again or runs good? might of not did any damage.
Old Mar 19, 2011 | 12:14 PM
Bojangles's Avatar
X2.
Im wondering if it was parked with low coolant or it leaked out over a period of time?
Old Mar 19, 2011 | 01:03 PM
TNRabbit's Avatar
Buy yourself a coolant pressure test kit. Quickest & easiest way to check the health of your cooling system.
Old Mar 19, 2011 | 01:59 PM
vital22re's Avatar
totally a bro
best idea.
Old Mar 19, 2011 | 04:54 PM
Sportsmanphil's Avatar
If the coolant was low, you might have hit the sensor with steam which is hotter than the water.
Step one is to crank the truck cold, fill the system as it warms up allowing it to burp. Allow the T stat to cycle at least twice in this process. Make sure the heater is on full so no air in there can later come out and cause you problems again.
Keep an eye on the temp gauge during this time.
If you get coolant back in the truck and all is well, dont quit there as there is more than likely a leak as the coolant system is a sealed system and if any is missing it had to escape somewhere.
Do not over look the Rad cap, if its bad it will push to the overflow bottle too early and leak through the bottles overflow.
And as said earlier, check the oil. I swear some people have more head gasket failures on the 22RE than they have flat tires.
Old Mar 22, 2011 | 02:02 PM
Thanks for all the helpful knowledge...Turned out to be the T-Stat stuck closed and there was no water in the oil so hopefully that means there is no damage to the head (Thank the lord).
Team420
Jan 12, 2021 04:57 PM
the1998sr5
Oct 19, 2016 12:48 PM
MadMax48
Jul 3, 2015 08:26 AM
atticus
May 29, 2002 03:11 PM
atticus
7
May 26, 2002 12:14 PM
