truck idles ok cold, runs rough after warm-up
Old Jul 16, 2008 | 07:36 PM
ddwyer's Avatar
This is a re-post that I am making to summarize new info and get new input.
I changed the engine in my 94 4x4 22RE after I skipped the timing chain. The 'new' engine has 115k and an unknown history.
The engine replacement went fine until I set the timing. I can get it to run perfectly when cold, but after it warms up, it runs really rough and almost stalls. I get no CEL or codes.
Things tried so far:
remove O2 sensor (set code, then re-installed and cleared code)
swap in original coolant sensors (2 pcs)
swap in original distributor
swap in original throttle body (with TPS)
I have not yet swapped in the original EGR valve.
Any other ideas would be appreciated.
Yont283
Sep 23, 2022 08:06 PM
Alex Bessinger
Jun 28, 2015 10:05 AM
sharrack
Jun 26, 2015 09:33 AM
Peteyg39@hotmail.com
Jun 26, 2015 08:15 AM
94hiluxZE
Jun 22, 2015 10:42 AM
