troubles with engine! code 4 and 6
hey yall, so recently my 1985 toyota pickup 4x4 has been being a paid. First it started by not wanting to start and i have had to jump start it a coulple of times, so i took the starter apart and cleaned it out then it worked fine for about a day or two. also since the whole starting problem it does this odd thing were when i drive it for about ten minutes and come to stop at a light, the check engine light comes on and when i pull away the engine stuggles to go, like as if it is running out gas, it does it through first and second gear then it stops and its fine. then it doesnt do it for a while. so i checked the light codes and it came back with code 4 and 6. just wondering if anyone had any input on how to make this stop!!! thanks!
It has code 4 and code 6, and code 6 says it is the ignitor the distrubitor and coil that could be wrong. It is just strange cause it will start fine then ill drive it for like 10 minutes then it wont start or when i stop at a light the check engine comes on
cyclist231
Jul 7, 2015 12:56 PM
Jnkml
Jul 6, 2015 01:20 PM
