Transmission & T-Case Questions
Old May 6, 2019 | 11:35 PM
weaselman's Avatar
Hi guys, It's been quite a while since I have posted. Or even been online.
I have an 87 4Runner with the Turbo 22RE
I have an R151F bell housing with R150F transmission. I could only find the bell housing, not the whole transmission. I think that means I have a chain driven Transfer case.
My questions are.
1. Can I do a dual tcase setup?
2. How can i tell which year transmission and tcase i have? I need to rebuild the t case. it sounds like its going to explode on deceleration. i also need a slave cylinder.
3. what would be my best clutch options? the orileys clutch option for a 87 turbo slips like crazy!
4. does anyone have a complete r151f for sale?
5. I want to do a driveline brake. any suggestions?
Thanks guys!!!!!!
Old May 7, 2019 | 07:14 AM
keycw's Avatar
5 Year Member
whole transmissions can be purchased through marlin, although they aren't cheap. they also have a clutch kit, and master/slave cylinders. I am currently running one of their transmission with their 1200lb clutch and OEM slave/master cylinders and steel braided line. I know I sound like a salesman here, but trust me im not. my w56 was marked as such, I think under the shifter boot? hard to remember. if the transmission is original to the truck I would think you could just use the year chart on the marlin website to figure out what you have.
Old May 7, 2019 | 07:37 AM
weaselman's Avatar
Transmission is not stock to truck. Turbo 4Runner only came with automatics. This is a swap I did long long ago. And I forgot to write down all the important information when I was putting together the build. Lolol.
92yota92
Engine Swaps
Dec 4, 2013 10:48 AM
Chainsaw_Willie
May 19, 2011 01:05 PM
forwardtocharis
12
Mar 24, 2009 12:54 PM
4wheeling
Oct 21, 2008 10:32 PM
bryan
May 21, 2005 06:33 AM
