Transmission swap
Old Sep 25, 2008 | 09:47 AM
treegrower's Avatar
Transmission swap
I recently bought a 93 SR5 w/ automatic trans, and find that I get a marvelous 13 mpg ! In my 92 w/ 5 sp I got 18-20 mpg. This 93 has a pretty solid frame, and in the rust belt, that is a significant issue, so I would rather swap transmissions than look for another truck. I am familiar with these swaps in American classics (my other truck is a 57 Chevy w/ 350, and I get 18 mpg), but don't want to assume Toyata swaps are the same. some questions before I start buying things:
Are the transfer cases the same from auto to manual?
Any need to change or modify crossmembers for the swap?
What about drive shaft lengths?
Will I need to change computers, or are there some electronic short-cuts which will be necessary?
Thanks in advance for tips
Old Sep 25, 2008 | 10:17 AM
space-junk's Avatar
theres a blue bar up above your post... 4th link from the left is search...
its an awesome tool to use...
Old Sep 25, 2008 | 02:43 PM
tc's Avatar
tc
Do you have a manual transmission?
It may be easier and more straightforward to regear the diffs down a step or two, as the MAJOR problem with the automatic is the MONSTER overdrive coupled to a relatively peaky and underpowered engine. This results in the transmission not locking up the torque converter or not being able to hold overdrive which dramatically increases your consumption.
Old Oct 22, 2008 | 10:04 PM
toyscraps's Avatar
Funny thing is, when you do searches, half the responses you find are just like this.....
Old Oct 23, 2008 | 03:31 AM
phildelfino's Avatar
OMG...LMAO
Very true though
Liadrin
Apr 25, 2022 02:54 PM
mskalmus
May 28, 2017 07:51 AM
jjrbus
Jul 17, 2015 07:06 AM
Poncho0206
Jul 10, 2015 06:21 PM
madxman21
Jul 9, 2015 10:26 AM
