Transmission Problem
Old Mar 18, 2009 | 05:07 AM
vj95's Avatar
I know its been asked before but cant find a definitive answer.
My transmission doesn't want to shift into over drive untill I am a long way down the road. And its getting worse. I've changed the thermostat with no improvement. I changed the coolant temperature sender ( I know it goes to the temp gauge). I dont really know where else to look.
Suggestions please.
Old Mar 18, 2009 | 08:21 AM
Lotus1's Avatar
What about the shift solenoids
Old Mar 18, 2009 | 08:53 AM
Lotus1's Avatar
Here's a great link to look at for transmissions...
http://personal.utulsa.edu/~nathan-b...autotrans.html
Not sure if yours is a A340F like mine is?
In any rate I would check the shift solenoids or the valve body.
I just had a situation with my auto 22re where it didn't want to move at all whether or not I had it in drive or reverse. I just replaced the shift solenoids yesterday and it seems to be working just fine. Time will tell though.
Good luck.
Old Mar 18, 2009 | 08:59 AM
vj95's Avatar
thanks for the reply. Seems to be related to engine warm-up. Worse on cold days better on warm days. When the engine is warm no problem. Even still when the temperature gauge shows the engine is warm in the morning it takes a while (a mile or two) before it shifts into OD.
Old Mar 18, 2009 | 11:21 AM
GSGALLANT's Avatar
The coolant temp sender (that displays the output on the instrument cluster), and the coolant temp sensor (that controls the transmission lockup), are two different things. Even though the sender for the guage is working correctly, it doesn't mean that the coolant temperature sensor is working correctly.
Old Mar 18, 2009 | 09:30 PM
wishmaster22's Avatar
Good luck.
is this hard to do?
Do I need to remove the pan cover. Hope not I had to retap a few holes and its not leaking, and I wanna leave it like that.
Old Jul 9, 2009 | 01:58 PM
savannah_born's Avatar
delete
Old Jul 9, 2009 | 04:28 PM
FredTJ's Avatar
Actually that behavior sounds perfectly normal.
Fred
Old Jul 10, 2009 | 05:34 AM
vj95's Avatar
Fred
Maybe normal for a 275,000 mile xmission, but it hasn't always done this.
Old Jul 14, 2009 | 08:52 AM
Country Hank's Avatar
Mines a manual but I would venture a guess that the O.D. system is vacuum actuated somewhere along the line?
Old Jul 14, 2009 | 03:53 PM
FredTJ's Avatar
No it's not.
It's an electronically controlled transmission and, by design, will not shift up into OD until it's up to operating temperature.
Fred
Liadrin
Apr 25, 2022 02:54 PM
Liadrin
Sep 1, 2015 06:44 AM
jjrbus
Jul 17, 2015 07:06 AM
Poncho0206
Jul 10, 2015 06:21 PM
madxman21
Jul 9, 2015 10:26 AM
