Transmission bearing noise in 4th gear
Old Jul 30, 2011 | 06:38 AM
FastLane1000's Avatar
I've done some searching and most transmission noises I read about are in all gears but 4th since 4th is 1:1 ratio? Anyways, I've been working on a friend's truck. It has developed a bearing noise in 4th gear more so in lower rpms. Trans is W56. any help would be appreciated.
Old Jul 30, 2011 | 08:27 AM
Ok since 4th gear is direct drive through the shaft does it mean there is a main shaft bearing that would be the culprit?
Old Jul 30, 2011 | 08:38 AM
Moonfish's Avatar
Shift the transfer case into neutral and do some more investigating. If the transmission is in neutral the input bearing is spinning but most of the others are not. In 4th the input and output ones should be spinning. There are two shafts in there parallel and I believe the input/output shaft is up higher so those are the bearings that go bad if you run it low in oil? You need a press to get at one or two of the bearings.
Sadly, I once pulled mine and did just the input bearing and some leak finished it off a few weeks later.
smthwsn357
May 1, 2024 07:28 AM
mskalmus
May 28, 2017 07:51 AM
mengquis
Jul 13, 2015 10:39 AM
razorman8669
Jul 12, 2015 12:13 PM
Poncho0206
Jul 10, 2015 06:21 PM
