Transmission
Transmission
Hi All
Could someone please tell me the differance is in driving with the OD switch on and off.
My shifting problems see to be not as bad with the OD off.
I do mosty city driving and almost never get to 70 mph even on the freeway.
Do I even need the OD on?
Thanks for the help!
Martin
Martin
OD allows the trans to engage 4th gear. Locking it out (turning OD off) just gives you 1-3 gears. Good for city and hilly driving. I think the autos also have another switch that affects shifting - raises shift points slightly
Is what you're saying that your transmission seems to downshift a lot and not stay in overdrive? Get used to it...lol. Overdrive is the top/fourth gear of the transmission. Otherwise, it functions as a three speed. The consensus seems to be the 3.0 mated with an auto transmission is not powerful enough maintain overdrive under load. Some even say it's due to inadequate factory gearing.
I only use overdrive on the freeway when it's relatively flat and doing highway speeds. Otherwise, it's not necessary...and really kind of a pain. Moreover, it's harder on the transmission and mileage and even not recommended with lots of hills and pulling weight.
EDIT: Looks like someone beat me to it...haha
TheBFA
Feb 15, 2020 06:55 AM
Odin
Sep 26, 2015 06:56 PM
FS[PacNorWest]: 1987 4Runner SAS, 22RE, 5Spd, Dual Cases, etc
toyotasaurus
Sep 24, 2015 03:30 PM
