TPS setting wacky!!!
so i just installed a new tps on my truck and when i jump the yellow connection on the driver side fendere well the truck still does not drop idle... i cannot get this motor to run perfect, i hate going to mechanics but im contemplating it now.
with the plug jumped i set the timing at -5* Before TDC, and when i unplug the jumped connection it stays at -5* before TDC. its supposed to more to around -12* before TDC.
Truck is an 84 pickup 22RE
I also get a pretty wicked wobble in the shifter when driving and it mellows out once i push the clutch in.
ive read just about every TPS thread on the internet and still can get this thing to time correctly.
Please help before i go spend a couple hundred bucks at a shop
Maybe your check connector is corroded have you cleaned it??
It can be corroded and you can not see it with your eye .
So the truck won`t idle so you can`t check your Throttle Position sensor?
That has really nothing to do with timing.
Blamalam
Mar 12, 2022 07:34 AM
Blamalam
Aug 16, 2015 12:29 PM
