Toyota Thermostat
Old Jan 6, 2009 | 06:58 AM
4Crawler's Avatar
Originally Posted by axekick
Is stant a brand name?
Yep, common maker of aftermarket t-stats:
- http://www.stant.com/brochure.cfm?br...ocation_id=168
I've also had similar results with the Motorad Fail Safe t-stat:
- http://www.motoradusa.com/products/f...rmo/index.html
Had one pop and lock open and when that happens you need to replace them, so I put the 2-valve Toyota part back in and it is still going strong.
Old Jan 6, 2009 | 07:59 AM
mt_goat's Avatar
Yeah I put a fail safe in my 95 Taurus and about a month later my heater hose blew on the interstate and it locked open. So I had to pull the dang thing out and replace it.
Old Jan 6, 2009 | 08:27 AM
87LVRunner's Avatar
Not unless you get the special Toyota t-stat designed to eliminate that problem ( TSB: 029032787 22R-E Engine Temperature Overshoot):
- http://www.4crawler.com/4x4/CheapTri...tml#Thermostat
I've been running the same 2-valve t-stat in my '85 for almost 10 years now, it still works perfectly and if I can get that sort of lifetime out of a part compared to only a few years out of a Stant or similar unit, I'll stick with OEM.
Wow that's awesome!
I replace my coolant once a year along with the t-stat. But, I also drain and replace brake fluid as well once a year. All fluid's with the exception of oil get replaced yearly actually. Tune-ups happen about every 10K. I guess what I'm saying is, I only run into issues if the part is defective. (that and I keep part manufacturers in business) Never believed in running it till it's worn out. Maybe I'll give the Toy t-stat a try again next go around.
Old Aug 3, 2015 | 10:54 PM
clok's Avatar
i bought a NTC thermostat from LC engineering and lasted 8k miles before it got stuck closed and always waited about 10-15 minutes for a perfect idle , replaced it with a oem toyota thermostat and now i get a perfect idle in 4minutes , i will never trust anything but oem ever again !!! that piece of ˟˟˟˟ NTC thermostat could have cost me a motor !!!!
Colington
Mar 8, 2020 09:51 AM
Sep 4, 2015 09:27 AM
nick b
Jul 11, 2015 04:38 AM
Poncho0206
Jul 10, 2015 06:21 PM
