Tow trailer with 7" Lift
Old Jun 1, 2008 | 12:20 AM
RoninStang's Avatar
Towing a trailer with 7" Lift ???
Hey,
Can you tow a small trailer (2 dirtbikes), with a 4cyl 4runner 5spd, with 4"susp lift and 3" body, 35" tires, and 4.88s?
Will I have any towing problems is my main concern?
Thanks
Old Jun 1, 2008 | 03:56 AM
CJM's Avatar
CJM
Dont think you willhave any issues other than needing a good drop in the hitch.
Old Jun 1, 2008 | 01:11 PM
abecedarian's Avatar
if you keep the trailer under 1000 pounds or so you'll have no problems. just give yourself extra room for braking and corners.
you'll need a receiver with the appropriate drop so the trailer sets level or slightly tongue down. you want the trailer that way because most trailer axles have a slight positive camber to them (the tops of the wheels tip out slightly) and if the tongue is above level, the trailer will have a tendancy to wallow side-to-side at speed
you should also have at least 10-15% of the total trailer weight on the ball (if the trailer, loaded, weights 1000 lbs, you want the tongue itself to weight 100-150 pounds or more) this helps prevent the trailer from wallowing as well.
if the trailer, loaded, weighs more than 1200 pounds or so, I recommend electric trailer brakes be added to the trailer and a controller in your truck.
I see you're in metric country, but you get the idea.
Old Jun 1, 2008 | 01:30 PM
Noltz's Avatar
Nah, you'd be fine with that light of a load. Get a 6" drop hitch and you're good to go. Princess Auto sells 'em for about $40.. $20 on sale
Old Jun 1, 2008 | 01:46 PM
I guess I gave up to much 411 eh?
Scatterbrain
14
Aug 31, 2015 06:26 AM
dropzone
Aug 11, 2015 05:16 PM
defrag4
Jul 31, 2015 10:50 AM
shadowbirdie
Jul 21, 2015 10:38 PM
Jeffreynmandy
Jul 18, 2015 08:26 AM
