torsion bar adjustment...help!
Old 06-24-2006, 02:48 PM
UGATruck's Avatar
I bought my 94 yota pickup a few months ago and it had 3" blocks on the rear and the torsion bars cranked way up for the front. I finally got around to it today to remove the blocks in the, install all new shocks, and put the torsion bars back to normal.
Those adjusting bolts aren't hardly moving!! If I turn the bottom bolt head, the top nut turns too. Plus, it takes all I have to turn it. So, without a buddy today, it was pretty much impossible to hold a wrench on the top nut and turn the bottom bolt head.
Any tricks to this? Do I need to just get a buddy over to hold the top nut while I crank on the bottom bolt?
Thanks!!!
Old 06-24-2006, 03:14 PM
ZUK
ZUK's Avatar
Yes, there is a little trick....Take a closer look at the nut on the top......you will see it's actually TWO nuts. They are locked together. You have to break them loose.
If you lift the front end up by it's center section then the adjuster bolt will turn easier.
Old 06-24-2006, 03:37 PM
MMA_Alex's Avatar
penetrating oil or some carefully applied heat (watchout theres fuel lines nearby) can really help get them broken loose if theyre rusted.
Old 06-24-2006, 03:44 PM
LOCKnGO's Avatar
Go to the dealer and get new ones, I bet one breaks or gets way to FUBARd to use again.
Old 06-24-2006, 03:54 PM
deathrunner's Avatar
Don't adjust without jacking it up. It's actually dangerous....it's easier to snap the bolt that way.
Old 06-24-2006, 04:04 PM
UGATruck's Avatar
Mine does not have the two nuts. Just one. Yes, I've been jacking it up via the front center IFS bar.
Old 06-24-2006, 04:15 PM
mastacox's Avatar
You're going to need two new bolts, I've broken those dang things so many times, mainly from dirt and stuff making it way up in between the nut and the bolt. Even with liberal amounts of penetrating oil, they broke.
Old 06-24-2006, 04:34 PM
spirtlanimilbus's Avatar
I Use Pb Blaster Then Stick A 22 Mm Boxed Wrench On Top And Hit It With The Impact Wrench As I Count The Turns Untill It Gets Too Damn Fast.... Its Better To Measure From What Ive Found...
Old 06-24-2006, 04:52 PM
AH64ID's Avatar
there is only one nut, if it turns with the front off the ground there toast... go get new ones... then remove... and be careful removing the old ones when they snap...
Old 06-24-2006, 05:39 PM
crackerjack's Avatar
is the torsion bar ajustment where I go to get one of my tires that tilt in from the top?
Old 06-24-2006, 05:40 PM
ZUK
ZUK's Avatar
1 nut.... ok...My 87 had 2 but I guess Toyota changes things. Sounds like you guys in Tennessee have serious rust probs.
Old 06-24-2006, 06:15 PM
AH64ID's Avatar
nope, torsion bars adjust ride height and spring preload.... camber is what your thinking of... go get an alignment
Old 06-24-2006, 06:41 PM
ok thx 4 reply was just layin under my trk lookin at all the places that have adjustment so if i screw torsion bar it will raise my trk ie getme just the 1/2 inch i need to get away from rubbib finder
Old 06-24-2006, 06:46 PM
UGATruck's Avatar
2 questions:
1 - should I take the wheels off when I jack it up and attempt to adjust the torsion bars?
2 - to replace the bolts with new ones, is it simply just pull the old ones out and put the new ones in? surely there is something else to it or otherwise how would adjusting a bolt adjust the torsion bar?
Thanks!
Old 06-24-2006, 08:45 PM
AH64ID's Avatar
2 questions:
Thanks!
1: Nope, leave em on
2: Yep, thats all there is to it.. the bolt is about 4" long, the tighter it is the more "preload" you put on the torsion bars.. the looser it is the less "preload"... you'll see when you take them out.
Old 06-24-2006, 10:05 PM
Toyopnoy's Avatar
My 86 4Runner has two nuts on the top. I'm gonna be installing some BJ Spacers and will probably uncrank the front a little. I can't get the top nut loose though. Anyone have any techniques on getting the locknut loose?
Old 06-25-2006, 04:14 AM
UGATruck's Avatar
Would it be good when I put the new ones in to coat the heck out of them with anti-sieze so that they won't get frozen again?
Old 06-25-2006, 07:33 AM
mt_goat's Avatar
Yes, I cover mine so thick with grease you can't see the threads and they adjust very easy that way. I can adjust mine down without raising the front end because of the lubrication.
BTW adjusting the t-bars will effect your camber adjustment, so you may need an alignment afterwards if you do much adjusting.
The older trucks have 2 nuts on top and the newer style only have 1 nut which you don't even need to hold while turning the adjustment bolt, very easy.
Rusted bolts make a real bear out of any simple job. I don't know how you guys in the NE get any work done on those rust buckets. You must buy PB Blaster by the case.
Old 06-25-2006, 01:01 PM
LOCKnGO's Avatar
Thats a good Idea!
I use so much on my junk I bought a gallon can of it and it came with a refillable sprayer.
Old 06-25-2006, 02:52 PM
UGATruck's Avatar
OK, I worked on it today. I was able to get one adjusted so I went to the other side. I broke that sucker clean before it budged any.
Off to Toyota tomorrow to get new bolts. I'll probably go ahead and do the other side while I'm at it. Glad I just bought some multipurpose grease cause I'm gonna coat the heck outta them suckas.
Quick Reply: torsion bar adjustment...help!
