Torque Wrench for Dummies 3VZE plz help
Old Oct 7, 2016 | 03:12 PM
toiyodah4WD's Avatar
This is an older 1/2" drive Craftsman. I'm using to tighten valve cover gasket bolts. Is the 4.15 over 30 where I want to be for appropriate torque? Thanks for any guidance.
Old Oct 7, 2016 | 04:10 PM
cbr600rx7's Avatar
No that's way to high!!!!
i don't remeber the torque on the valve cover gaskets but it's definitely not 30ft-lbs. Look up the specs but it's probably very close to 100 in-lbs but I don't remeber So I repeat LOOK IT UP. I think it's some where between 88-140 in-lbs. Look it up to be sure.
Old Oct 7, 2016 | 04:13 PM
millball's Avatar
No, No, NO!!! You will destroy the bolts!
The torque wrench you have is not suitable for tightning the valve cover bolts.
What you need is an inch-pound wrench.
4.15fp= approx 50 inch pounds; a very light torque.
What is really necessary is that the bolts are lightly snugged onto the metal spacers in the valve cover without crushing them.
If you have a feel for what is really going on, no torque wrench is really necessary.
The fact that you had hoped that your 1/2 in drive wrench was a suitable tool shows that you are one who may indeed need the appropriate inch-pound wrench.
Old Oct 7, 2016 | 04:43 PM
Thanks! I actually bought a light 1/4" torque wrench but do not have an extension socket. For the 1/2" shown I have one. Could I just go approx. half way between 0 0 -- and 1.38 / 10?
Old Oct 7, 2016 | 04:55 PM
RJR's Avatar
RJR
No, the 1/2" drive wrench won't be very accurate at those low values. Do it right and get a 1/4" to 1/2" adaptor (may need to get a 1/4-3/8 and a 3/8-1/2 adaptor and stack them) so you can use your 1/4" drive wrench. Or get a 1/4" drive extension. You'll find lots of uses for either of those solutions.
Old Oct 7, 2016 | 05:13 PM
will do on 1/4" extension, thanks guys. i hope i can read that right
Old Oct 7, 2016 | 05:20 PM
RJR's Avatar
RJR
First rule of working on these old trucks - never pass up an opportunity or an excuse to buy another tool!:-)
toiyodah4WD
Oct 12, 2016 04:22 AM
Oldtiredhippie
Oct 9, 2016 11:41 AM
Dgavin9
Oct 8, 2016 09:59 AM
jgentleman
Oct 7, 2016 07:30 PM
toiyodah4WD
Oct 7, 2016 05:17 PM
