Torque of front brake dust shield/Backing plate on 1988 Toyota 4x4 truck
Old Dec 28, 2024 | 07:11 AM
WALT1256's Avatar
Is the torque for the bolts (7) that secures the dust oil seal to the dust shield/cover 34 ft. lbs? I used a torque wrench set to 34 ft. lbs which resulted in the bolt breaking when torquing. Now, I'm hesitant to torque the rest of the bolts for fear of breaking them.
Old Dec 28, 2024 | 08:03 AM
coryc85's Avatar
If I am reading the FSM correctly here, it says 13ft lbs for the dust cover bolts
Old Dec 28, 2024 | 02:04 PM
Melrose 4r's Avatar
5 Year Member
Which is low enough that i wouldn’t spend the time getting out the torque wrench. Just “pretty tight” with a 3/8 ratchet and one hand.
Old Dec 29, 2024 | 05:46 AM
WALT1256's Avatar
Thanks for replying. Your diagram does read 13 ft-lb. Can you provide the manual you got the torque spec from? Also, have you ever had to remove the dust cover on your 1985 Toyota truck and had to re-torque it? If so, any issues with oil leaking around the dust oil seal or any other issue?
skoob
Nov 7, 2014 03:02 PM
scjfly
Dec 10, 2012 02:01 PM
sdsurfer
Sep 22, 2011 05:30 PM
cervesa33
Jun 9, 2009 11:49 AM
Bigblock
Jun 27, 2007 01:01 PM
