Tool for holding timing gear when removing head
Old Oct 11, 2013 | 06:49 PM
killer305's Avatar
Is there a tool and is one necessary?
The last time I did a head gasket on a 22re I remember the timing gear dropped down slightly when I took the head off.
I was able to use a pry bar to lift it back into place when I installed the head but I imagine there is a tool to hold it so you cannot accidently skip a tooth?
Does anyone know where I can get one?
Old Oct 12, 2013 | 04:53 AM
Rerunn's Avatar
There isn't a tool. The tool i used is call plastic zip ties! Just zip tie the chain to the cam gear before removal. When going back on if you rock the crank back and forth and pull up on the gear at the same time it'll go on.
Old Oct 12, 2013 | 10:48 AM
killer305's Avatar
Cool thanks for the reply
Old Oct 12, 2013 | 11:43 AM
SCToy's Avatar
I used zip ties and a piece of string holding it up to the hood.
voiddweller
19
May 2, 2016 09:10 PM
DacodaYota
Sep 2, 2015 02:13 PM
85run
Jul 8, 2015 11:20 PM
hexrain
Jun 27, 2015 06:17 AM
