timing marks
Old Dec 23, 2014 | 04:05 PM
barrentine's Avatar
timing marks
Hello,I have a 1989 4x4 deluxe pickup.I put a new engine in a while back and I set the timing by ear because someone had helped themselves to my timing light.Well I finally got it back and thought I would check the timing on the fresh 22re.I jumped the TE1 & E1 probes.By the way what do yal use as a jumper?So I start the engine and at idle the mark on the crankshaft pulley does not quite make it to the tab on the timing cover.when I move the dist.all the way c/wise it still doesn't make it and engine runs rough.I then set by ear again to point where it runs good and shoot it with timing light and its no where close.am I off a tooth on the dist?Any suggestions appreciated
Old Dec 23, 2014 | 04:15 PM
rustypigeon's Avatar
Did the idle speed slow down when you jumped te1 and e1? You can use a paperclip. Are you sure you jumped the correct terminals?
Old Dec 24, 2014 | 11:39 AM
scope103's Avatar
Being off a tooth on the distributor moves everything 28°, so you won't be able to turn the distributor to a point where the timing mark is on the scale. So that could be your problem.
I've heard on this site (though never seen) where the rubber in the harmonic balancer fails, allowing the outer part to rotate against the inner. So I'd get a plastic straw to drop in the #1 spark plug hole, and check that TDC is in the right place.
By the way "set the timing by ear" is just another phrase for "I blew a hole in the top of a piston."
Old Dec 24, 2014 | 12:12 PM
That sounds like it could very well be the problem.
The fact that he said that it ran rougher as it got closer to the timing marks makes me think the distributor is not on the wrong tooth.
Old Dec 28, 2014 | 08:06 PM
88sasturbotoy's Avatar
try not to jump it and see where the mark is at. I think theres like 0 5 8 12 or something like that I set mine at 12 without jumping it
Eggslinger
Jun 8, 2019 03:32 PM
Sep 4, 2015 09:27 AM
smiley52
Jul 11, 2015 05:16 AM
crashburnoveride
Jul 10, 2015 06:39 AM
