timing issues
Old Feb 11, 2007 | 03:15 PM
tampabayota's Avatar
timing issues
ive tried searching but nothing on this.I can not time my truck 1986 4x4 rtec .every thing is at tdc. jumper in conector idle down.timing is about 10 degrees advanced.i turn the distributor all the way back to retard but it wont go past the stops. We pulled the dist and moved one tooth then put everything back in and the truck wont start.any help what am i doing wrong .It is running now but i think it could run a little better .
Old Feb 11, 2007 | 03:26 PM
Targetnut's Avatar
when you jumper the diagnostic connector what does the check engine light do?
Old Feb 11, 2007 | 03:50 PM
it flashes
Old Feb 11, 2007 | 06:03 PM
Sonofmayhem's Avatar
that is telling you a code i believe....
Old Feb 12, 2007 | 09:54 AM
dcg9381's Avatar
Any luck, tom? TPS and other sensor can impact ECU control of timing also.
Old Feb 12, 2007 | 10:41 AM
Yotapup's Avatar
What are your codes?
bigjstang
Jun 2, 2025 03:56 PM
Regency
20
Jan 3, 2020 07:43 PM
coryc85
Sep 9, 2015 06:24 AM
msane99
Jul 11, 2015 08:08 PM
colinmil
Jul 6, 2015 04:03 PM
