timing cover plate
for starters it a 1988 pickup with a 22RE and i have no label under hood for the timing degrees, or valve lash. And instead of a timing plate with degrees its got a pointer that points at the pluuy which has a big notch and a little notch. I need to set valves as they are noisey and the distributer has been moved any help. and yes i know about the jumper thanks
Jun 1, 2021 01:51 PM
