timing chain play. pics
Old 12-18-2013, 07:21 PM
twoyotas86's Avatar
How bad is this for timing chain wear? guides are intact.
Old 12-18-2013, 07:51 PM
Ryan G.'s Avatar
its pretty bad. rebuild time
Old 12-18-2013, 08:03 PM
twoyotas86's Avatar
Thats what Im thinking. The engine runs great and was rebuilt a few years ago. Just looks like alot of slack.
Old 12-19-2013, 06:20 AM
Stuwy123's Avatar
There is a timing chain tensioner that takes up some slack but on the other side.
I don't know the spec's for slack on the 22re timing chain. I'm sure there is a spec.
Are you a top dead center in this pic?
Are you sure the guides are intact? Mine was "intact" but it had actual just broken on eyelet and was resting on the housing wall. Given a little longer, she would have popped.
It's a cheap fix and good piece of mind. Why are you digging into the engine when it was rebuilt not too long ago?
Old 12-19-2013, 07:52 AM
93 Toyota 4x4's Avatar
Originally Posted by Stuwy123
....Are you a top dead center in this pic? .............
why does that matter????
Old 12-19-2013, 08:39 AM
twoyotas86's Avatar
I bought it from a friend to swap into my truck. If you look at the pics you will notice its not in a truck. I was digging into it to check the guides. It has a few years on the rebuild. I know it runs good because I heard it run before we took it out for his 4.3 swap.
Old 12-19-2013, 01:22 PM
lobukbuild's Avatar
check the tensioner. you can see it from the top with a flash lite. its on the intake side down by the crank.
icentropy
09-16-2020 02:47 PM
bryan34w
07-06-2015 05:53 PM
Quick Reply: timing chain play. pics
