Timing chain broke! 22r and 22re heads the same?
Old Sep 12, 2007 | 11:18 AM
Adawg_08's Avatar
well, my TC broke yesterday. I did some searching.
I thought I could just through a new timing chain kit on there and it would be good. but I probaly bent some valves. My friend has and 86 22r motor with 250,000 miles on it. I can probaly get it for 100$. Is it ok to put this head on my 88 22re? I only got 102,000, but i think the odometer is wrong.
what would you guys do? please help
Old Sep 12, 2007 | 11:31 AM
tampabayota's Avatar
same thing happened to me. i got new valves and had the head re worked. then put a new chain kit from engnbldr. if you go with him just be careful on the way you put in the new crank sprocket on, i did it backwards and the chain broke again so i had to do the job two times, not fun.
Old Sep 12, 2007 | 05:36 PM
Adawg_08's Avatar
I pulled the valve cover off today and the chain is fine. The right guide broke into 2 and the bolt is missing. So I guess that the guide fell into the gear mesh and knocked it off of timing? Is that possible?
Can the valves still be damaged? I am still going to pull the head tommorow and check the valves.
Ichneumon
Sep 27, 2015 04:21 PM
CJ94yota
Jul 3, 2015 10:14 PM
83flatt
Jul 2, 2015 10:30 AM
paxanders
Jun 21, 2015 06:29 AM
