Timing at 20*
Old Apr 5, 2009 | 05:08 PM
j0hNnI's Avatar
Originally Posted by sinneDBTB
i've don alot of engine work recently and i just got everything put back together and took er for a test drive. major power loss under load. idles and revs fine but it wants to stall out when i let out the clutch and it has a "can of spoons" type rattle under load.
i checked the timing with a light and it reads 20* advanced off cyl 1. if i turn the dist. wont that throw off the even side (2,4,6) ? is it possible that the timing belt is off a tooth or two on the odd side (1,3,5) and could advance my timing 10*?
heres a list of my recent engine work:
-plenum cleaned out
-intake cleaned
-injectors sonic cleaned and serviced
-new top end gaskets
-new wires, dist. cap and rotor. (plugs 3 months old)
-new fuel filter
-new o2 sensor
-new air filter
-*erg coming off as soon as i figure out the timing.
acctuly in some old chevys like camaros that 78 berlinetta model usually had a timing problem they could be off a tooth an run but you could feel a difference
Old Apr 5, 2009 | 07:43 PM
Justinlhc's Avatar
problem solved!!!!
so the cam timing was way the heck out. the left was 6 teeth counter clockwise and the right was 1 tooth ahead clockwise. all in all not too hard to fix. i didnt have the hydro tensioner either. i also disconnected the egr. seems to have yielded some gains in throttle response.
all in all with the work that i did my truck sure seems a lot more peppy!
thanks everyone!
Awesome. Don't forget to stick a 1k ohm resistor in that EGR temp sensor so it doens't throw a code at you.
Old Apr 5, 2009 | 08:24 PM
sinneDBTB's Avatar
no temp sensor on my truck either. that must have come out some time after 1990. but thanks just the same.
Old Apr 5, 2009 | 08:26 PM
Justinlhc's Avatar
Wow. You guys have all the luck.
Old Apr 14, 2009 | 01:53 PM
  #25
sinneDBTB's Avatar
ok, so on top of all the bad luck i am having recently. it seems my timing is yet again off (by only a small amount this time) my truck is stuttering like it did before with some minor power loss.
it has only been maybe 1000km since i adjusted it last. is there a reason that i am missing for the timing to slip like this? my belt is as tight as it can get with the tensioners. why would it go out like this? again?
Old Apr 17, 2009 | 01:12 AM
  #26
TNRabbit's Avatar
Worn distributor?
Old Apr 17, 2009 | 07:54 AM
  #27
sinneDBTB's Avatar
spark plugs
Eggslinger
Jun 8, 2019 03:32 PM
Sep 4, 2015 09:27 AM
thefishguy77
Jul 30, 2015 10:59 AM
smiley52
Jul 11, 2015 05:16 AM
