Timing!?!?!
Old Dec 21, 2009 | 03:19 PM
  #81
bone collector's Avatar
the MC dashpopt valve is in the aircleaner on the bottomside of it. has 2 or 3 vacuum hoses attached to it. try cleaning it might help. Im glad the choke wire helped
Old Dec 21, 2009 | 03:34 PM
  #82
1990yota-pickup's Avatar
Re-read my post.
I did NOT say that if the t-chain jumps a tooth that it would not effect the ignition timing. Cam timing controls the opening and closing events of the valves. Under normal operating conditions.... Ignition timing CANNOT effect cam timing. Ignition timing controls the spark, under normal operating conditions, the spark CANNOT effect the mechanical opening and closing of the valves.
If this is wrong.... please explain.
gNARLS.[/quote]
  #83
JUST GO GET THE Manual tats whats it's there for
Old Dec 21, 2009 | 06:41 PM
  #84
briholt's Avatar
Originally Posted by camo31"10.50"
no dashpot here??
i dont even know what it is actually..what it looks like or does lmao
well, it might look like a little flying saucer with a tube on it. Someone mentioned its location above. On my EFI it looks like this: (the throttle sets on it just to the left of this pic. when you let off the gas the dashpot catches your throttle so that it doesn't slam shut and instead slows it down some. But if it's clogged up or not working right, it might be really slow--it's sort of acts like a shock absorber for your throttle.)
Old Dec 21, 2009 | 07:35 PM
  #85
camo31_10.50's Avatar
jeez 1990 yota pickup...you need to read the rest of the thread..we're wayyy past the timing part dude.....and the manual doesnt do shat for my problem...sorry to disappoint you but it doesn't help at all...
well my air cleaner is not on my truck(fiddling with the carb WAYY too much to leave it on there LOL)..and all the vacuum hoses that went to it have been plugged for about 15,000 miles....theres a diaphragm in a brass case that isn't hooked up (but was before) that is right here
its the brass lookin thing to the left bottom of the pic..idk what it's for..but i was told i don't need LOL
Old Dec 23, 2009 | 04:37 PM
  #86
im not too sure if i wanna fix the problem guys LMAO!! it idles at about 550-1000 rpms (depends on how it's feeling..sometimes it idles at 1000 sometimes 550 LOL)
But other than it...it runs amazing LOL and seems to have a lot more low end grunt than before and it's getting perty good gas mileage LOL
with it running lean like it is...would i be able to advance the timing a bit to take advantage of the lean mixture??? without screwing something up of course...
Old Dec 23, 2009 | 04:52 PM
  #87
xxxtreme22r's Avatar
I would gauge the timing advance by the way the plugs look now. If they are really white I wouldn't mess with anything but maybe lowering the ign timing a little. Which reminds me I got to check out my plugs after 300 miles on my rebuild lol.
Old Dec 23, 2009 | 05:00 PM
  #88
i had this problem on my old 82.. pickup the main problem was that the carb.. need a good cleanning.. so look into that...
Old Dec 23, 2009 | 11:08 PM
  #89
read the thread...i rebuilt and cleaned the carb already dude.........dang
sooo, if the plugs gots a lot of white on em..don't mess with the dizzy?
if they aint got no white, i can advance it some..it's sittin right at about 8* right now..i was thinkin take it to like 10* or close to 12* lol
Old Dec 24, 2009 | 06:21 AM
  #90
I've got mine at 5 1/2 and I swear it pings going up mountains lol. ENGNBLDR told me do go no more than 6 on the carbs. Since they only supposed to be at 0.
Old Dec 24, 2009 | 10:03 AM
  #91
hm...well i need to adjust my valves as well..they're kinda noisy LOL
anybody know a goooodd write up about doin it?? i've never watched my mechanic do it lol and the chiltons don't help...
Old Dec 24, 2009 | 10:13 AM
  #92
the FSM download file worked for me. keep in mind depending on how wore the adjusting screws are on the valves you may or may not be able to quiet them up. and remember to set when hot not cold. and do not run motor with valve cover off. Been there done that. OIL ALL OVER THE PLACE. These 22rs aren't like 350's lol
Old Dec 24, 2009 | 10:15 AM
  #93
yea i forgot i downloaded that, i'm good now though! LOL!!
i kinda had an idea..but now i know exactly what to do
Old Dec 24, 2009 | 10:17 AM
  #94
sorry to hijack but hey how much you lookin to get for those x-terrains?
Old Dec 24, 2009 | 11:15 AM
  #95
yea i wish it was like a 350 LMAO!! it'd make a couple of things easier lol
and the X-terrains go with the truck, sorry
they are still basically brand spankin new, paid $350 for em, but they cost over $800 new LOL, yea i got an amazing deal!
and my Brother in-law has first dibbs on the truck LOL unless somebody was to give me like..$500 or $1000 more than what he will lol
Eggslinger
Jun 8, 2019 03:32 PM
Sep 4, 2015 09:27 AM
thefishguy77
Jul 30, 2015 10:59 AM
smiley52
Jul 11, 2015 05:16 AM
