Tie Rod and Idler Arm
Old Feb 4, 2010 | 12:12 PM
jaredbishop's Avatar
I need to replace the outer tie rod and the idler arm. I'm going to pick up Moog brand for both. I'm going to either rent or buy A pitman arm puller, tie rod end puller and a ball joint puller.
Any advice to ticks not in the FSM that I should know about?
Old Feb 4, 2010 | 01:48 PM
OutlawMike's Avatar
Nope, pretty easy to do with the right tools, and you look like you are getting them. Should be an easy job.
Old Feb 4, 2010 | 01:57 PM
So I was looking at the parts I was told to replace and I don't see anything wrong, bent or broken. It is all coved in oil & grease . I'm not a great mechanic but we'll see what happens on Saturday.
I was able to borrow all the tools from Autozone, just had to put down a deposit.
Old Feb 4, 2010 | 01:59 PM
iamsuperbleeder's Avatar
be sure to get a propper alignment once you're done, otherwise it sounds like you've got it covered
Old Feb 4, 2010 | 02:24 PM
I'm going to have an alignment done at Big O when i am done. They are also doing the Saftey Inspection.
kawazx636
Oct 6, 2021 03:03 PM
primordialbeast117
Dec 19, 2015 12:23 PM
JookUpVandetti
Sep 30, 2015 08:58 AM
beltcutter
Sep 30, 2015 06:14 AM
tylermx71
Sep 29, 2015 08:49 PM
