Thermostat question
Old Aug 2, 2010 | 07:02 AM
VATD's Avatar
Thermostat question
I replaced the thermostat in my 1994 22re 5spd 2wd. The only problem is now the temp gauge on the dashboard barely comes up off the lowest temp. I spoke to a mechanic and he said it was probably something to do with the balast's.
Before I replaced the therm it was locked on the lowest temp, now it atleast comes up a bit but the gauge still isn't correct. Any idea what the problem might be?
Thanks in advance for your input.
Old Aug 2, 2010 | 07:30 AM
thook's Avatar
Either the wiring, connector, or the sending unit itself. Inspect the wiring for any damage. If you don't see anything obvious, then it's probably the sending unit. I know there's a way to check, not sure what that is at the moment. Never had to do it. Might run a forum search on that.
BTW, check the rating for your thermostat. It needs to be rated at 180*. Run a forum search on 22re thermostat.
Old Aug 2, 2010 | 08:57 AM
myyota's Avatar
What temp thermostat did you use ?.
Old Aug 2, 2010 | 10:50 AM
VATD's Avatar
I replaced it with an OEM therm, 90916-03078
I'll try searching again.
Old Aug 2, 2010 | 11:13 AM
myyota's Avatar
Try replacing the sending unit, i had one go bad and the gauge would read just above the cold line all the time. The new sending unit fixed the problem.
the1998sr5
15
Jul 14, 2020 08:35 PM
makemusic116
Aug 2, 2015 05:23 PM
makemusic116
Aug 2, 2015 04:40 AM
TJWilly
Jul 31, 2015 02:05 PM
4Runnin2000
Jul 29, 2015 06:09 PM
