Temp Sensor near Themostat
Old Aug 8, 2008 | 07:46 PM
thook's Avatar
And an FYI, in case you didn't know RayneTorrin, that's the vacuum switching valve for the a/c idle up valve in his pic. If you don't have one, it won't hurt anything, but your idle will drop a little when you turn the a/c on. Well, suppose to anyway.
Old Aug 9, 2008 | 08:12 PM
RayneTorrin's Avatar
yeah no AC. hmmmm i'm hosed because the correct wire is missing. Thanks for the info
Old Aug 10, 2008 | 04:48 AM
4runnerx3's Avatar
thook, I'm glad you found that info on "temp sensor No. 2". That's the first diagram I've ever seen that shows it. I think it's strange that the FSM never mentions or shows it.
Old Aug 10, 2008 | 06:03 AM
thook's Avatar
Well, it took me getting a part number....although, the numbers I gathered off the switch still weren't the right one....and really getting the parts fellow at dealership to dig for info through his computer.
I've still not made the concentrated time to look over the TSB and figure out how the switch functions, but I suspect it's affecting how my vehicle runs. My vehicle does seem to be displaying the symptoms it describes.
RayneTorrin....
Keep digging around. It may be buried/dangling somewhere under the intake manifold. Hopefully, no one cut it off. If so, it's not a complicated repair at all.
Old Aug 10, 2008 | 10:18 AM
  #25
thanks Thook. Yeah it's not a hard repair. but if they cut off the wires it's going to be a pain to figure out wich one they are. anywho thanks all.
Old Aug 10, 2008 | 10:47 AM
  #26
thook's Avatar
Well, you don't have too many single wires to choose from, so it won't be too bad...I hope...lol!
Good luck...
jmoua
Mar 29, 2023 03:42 PM
TACOJO
Nov 27, 2015 05:26 PM
rjtrials
Aug 6, 2015 07:25 PM
bighaydn
Aug 4, 2015 07:17 PM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
