Teflon Tape on Oil Sender?
Old May 9, 2008 | 03:04 PM
DanStew's Avatar
Does the oil sender ground to the block? Or is it OK to use Teflon tape when threading the oil sender into the block?
Old May 9, 2008 | 03:29 PM
abecedarian's Avatar
As a rule of thumb, if there is only one terminal on the sending unit, whatever it is for- oil, temp, etc...; it grounds through the block.
It's been my experience though that two very tight wraps of tape down near the end of the fitting won't interfere with the grounding since the threads will cut through the tape and make a connection to the block but will help sealing high pressure fittings like oil and fuel. If after tightening there is tape showing outside of the block, there's too much tape.
Old May 9, 2008 | 04:19 PM
My99's Avatar
I taped mine up. No problems and I was pretty liberal.
Old May 9, 2008 | 04:28 PM
DanStew's Avatar
Thanks guys!!! I used a little bit and tightened it up.
Old May 9, 2008 | 04:32 PM
SoCal4Running's Avatar
I agree with everything said above, but my TCI trans pressure guage said not to use tape because it will crack the case. I think their lawyers made them wright that though.
Old May 9, 2008 | 05:02 PM
Nothing will crack the case if you pay attention and don't tighten it up that hard.
chukarhunt
Dec 8, 2019 11:39 AM
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
defrag4
Jul 31, 2015 10:50 AM
calderp
Jul 27, 2015 09:58 AM
highonpottery
7
Jul 18, 2015 02:48 PM
