tapping noise in 3.0L V6 1990 4Runner
Old Nov 5, 2009 | 07:02 PM
Jeremy11's Avatar
I first bought my 4runner and i had to basically get the engine rebuilt because 5 of my rods were burnt.
i replaced:
all 6 rods/bearings...
new crank kit
new oil pump
While the engine as being worked on the lifters were not removed.
can they still be affected?
or can they be the cause of the tapping i hear while my truck is on?
It starts as soon as i turn the truck on and it gets louder and clearer when
i accelerate.
It is a auto. 4x4 1990 4runner sr5
also on my exhaust pipe by the catalytic converter there is some sort of foil that wraps around the exhaust and next to it is a copper tubing twirled around the exhaust also. it was like this when i bought it.
any help appreciated
Old Nov 5, 2009 | 09:18 PM
Matt90V6SR5's Avatar
Hey jeremy does it tap in park,can u pop the hood and hear it? My 90 V6 4Runner taps when I drive it but when the hoods up in neutral it does nothing.
Old Nov 5, 2009 | 10:29 PM
Built2Grind's Avatar
lifters? i dont thing the 3.0's have them as they are direct acting cams, your lash could be too big, mine does the same tapping noise. so far i have blamed it on injector noise and too much lash. slightly loud valves are better than quiet ones because that way you know the valves are not hanging open and burning.
Old Nov 6, 2009 | 12:32 AM
Thats interesting b2g,so no worries then.Is yours quiet at idle? And what does removing sway bars do? Just curious,I think my 4Runner has them.
Old Nov 6, 2009 | 05:37 AM
mine makes a little noise at idle but not much and the sway bars keep body roll down but reduce articulation. i removed them so i could flex a little more off-road and keep my traction a little easier. it does let the truck roll a heck of a lot more though, it kinda feels like the indiana jones ride at disneyland.
Old Nov 6, 2009 | 07:29 AM
Jeremy11's Avatar
It taps in park also.. I pop the hood but ccant really tell where it is coming from.
so it cant be the lifters making that noise. either because they were sitting in no oil for too long? i have a fuel injector seal leak that im replacing today. could that also be the tapping noise in some way?
but like i said it starts as soon as i turn my truck on and when i accelerate it just gets louder and clearer
Old Nov 6, 2009 | 08:26 AM
90-3vzeslug's Avatar
the 3.0 does not have lifters. not sure where you are getting the idea that it does. valves prob need to be adjusted and thats whats causing your noise
Old Nov 6, 2009 | 09:20 AM
OutlawMike's Avatar
Either valve noise or injector noise.
The 3.0's have notoriously loud fuel injectors. Mine got worse when I had them cleaned/serviced. With an auotmotive stethoscope you can diagnose it down pretty quickly. When I listen to my injectors with the stethoscope, it hurts my ears, those things are loud.
Old Nov 6, 2009 | 02:23 PM
Jeremy11's Avatar
ok so no lifters... got it.
so it could be either badly adjusted valves or fuel injectors?
if it is my fuel injectors i could figure it out with an automotive steth...
and what about my valves...
Thanks for all your help guys. Really appreciate it
Old Nov 6, 2009 | 03:53 PM
Yeah thanks for helping me 2,thats kinda spastic fuel injectors get louder after cleaning them.Now I get a clearer picture of my injector clicking noise.
Old Nov 6, 2009 | 04:16 PM
Jeremy11's Avatar
fixed my high idle.. turns out the mechanic who worked on it didnt tighten the idle screw. now i just gotta fix that tapping noise. or at least find out for sure whAt it is.
Old Nov 6, 2009 | 04:20 PM
Jeremy11's Avatar
Feel kinda dumb
dont know why i didnt think of tightening the idle screw. now my truck is missing!=/ timing done wrong??? and still trying to repair the tapping
Old Nov 6, 2009 | 05:40 PM
search 3vze valve adjustment, i believe there was a really nice write up on it. also for the timing search the fsm for your truck. there are links on here.
Old Nov 6, 2009 | 11:22 PM
Good luck Jeremy sounds like your motor is a PITA.
Old Nov 7, 2009 | 08:51 AM
Jeremy11's Avatar
Lol. thanks guys
hopefully my truck will be runnin better once my injector seals get replaced
Old Mar 26, 2010 | 07:49 AM
hermyboy3000's Avatar
Jeremy, did the injector seals fix your problem?
Old Mar 30, 2010 | 04:49 PM
Jeremy11's Avatar
I figured its just the fuel injectors themselves or the infamous toyota tick. Still ticks
Old Dec 21, 2015 | 06:20 PM
Mark Miller's Avatar
I just paid 4k to have my 3.0 rebuilt and now it ticks bad.....took it to a Toyota master mechanic to adjust the valves and it still ticks.....could it be the fuel injectors? What about getting rebuilt rockers does that help ?
smilen724
13
Nov 8, 2015 04:11 PM
zombie_barbarossa
Oct 2, 2015 10:54 PM
Jdgarrison
Oct 1, 2015 02:11 PM
meatballs
Sep 16, 2015 06:25 PM
anniesball
Sep 7, 2015 11:20 AM
