Tail light upgrades
Old Jan 20, 2019 | 05:56 AM
ToyotaYeti86's Avatar
Tail light upgrades
What options do we have for tail light upgrades as far as LED etc? Links appreciated
Old Jan 20, 2019 | 06:33 AM
Paul22RE's Avatar
5 Year Member
I bought these, you need to change flasher to avoid the LED fast flash when you install most LED directionals:
1157 2 Tail/brake lite bulbs: https://smile.amazon.com/gp/product/B076YT323X/ref=ppx_yo_dt_b_asin_title_o00__o00_s01?ie=UTF8&ps c=1
1156 6 directionals/backup: https://smile.amazon.com/gp/product/B0721FNCWP/ref=ppx_yo_dt_b_asin_title_o00__o00_s01?ie=UTF8&ps c=1
Flasher: https://smile.amazon.com/gp/product/B00JXLHE8S/ref=oh_aui_search_asin_title?ie=UTF8&psc=1
I got 4 LED T10 bulbs for the license plate and parking light bulbs on eBay
Old Jan 20, 2019 | 09:59 AM
dropzone's Avatar
Fossilized
For the flasher unit, I have used a Tridon EP-35 unit,it was a direct replacement for my 94
not sure how far you want to go but I cut out the back of the light housings on my 4runner brake lights:
Originally Posted by dropzone
Did a few miscellaneous projects today before I tore into the transfer case
After a few years of using zip ties to mount the license plate and front turn signals figured it was about time to do something a little more refined
Center mounted the license plate with some counter sunk bolts welded on the winch mount
hard mounted the turn signals
when I made version 1.0 of my LED taillights I got a little crazy with clear epoxy and it ended up obstructing some of the LED's.
version 2.0 came out a little better. New one on the left, old on the right
Old
new
Occupation of the garage has begun
Flasher stuff:
Was feeling like crap all day so all I got done was as swapping the stock turn signal flasher for an EP-35. It is LED compatible.
the flasher is sort of a pain to get to. It is mounted under the dash to the left of the steering column.
pulling the HVAC tube out of the way helps get you a little more room
Places will tell you the EP-35 isn't compatible but it was a direct replacement
Eliminated the hyper flash
https://www.instagram.com/p/BscJQEEBJBF/?utm_source=ig_share_sheet&igshid=t9qj685p8q5r​​​​ ​​
Amazon has a complete replacement LED housing
Amazon Amazon
Old Jan 20, 2019 | 11:30 AM
Paul22RE's Avatar
5 Year Member
Yeah, the flasher I used was not a direct plug-in for a 92
zarguy
Dec 29, 2011 10:00 AM
reaj
Oct 9, 2011 10:13 PM
Skides
Apr 2, 2009 08:21 PM
Fo_SheeZy
Mar 7, 2008 11:55 PM
rockb
Feb 4, 2008 03:19 PM
