Tach reading low.
Old Dec 16, 2012 | 01:42 PM
bbrideau's Avatar
Tach reading low.
So a few months back i did the sr5 gauge cluster swap into my 88 22re. The tach has never read correctly. max is 4-4500 rpm roughly. the tach is from an 89 was told it was a 4 cyl but im thinking it might be from a 6. is there any way to make the tach read right or am i stuck with either getting a 4 cyl tach or an aftermarket one?
Old Dec 16, 2012 | 03:47 PM
combatcarl's Avatar
https://www.yotatech.com/forums/f116...w-pics-179106/
Read thru there. Everything you need to know.
Old Dec 17, 2012 | 02:02 PM
bbrideau's Avatar
Thanks. i saw that thread quickly browsed it must have missed the part about changing the resistance! so im assuming that potentiometer will adjust my resistances
Old Dec 17, 2012 | 02:36 PM
bbrideau's Avatar
so that write up is for 2nd gen gauge cluster. i have my first gen one apart but its a lot different inside.... anyone know where to test resistance on the first gen cluster and how to remove the plates without breaking anything.
Edit: figured it out. thanks again for the help. gonna go plug it in and see if she works!
Ironmike4x4
Feb 3, 2016 11:13 AM
sanctfy
All Other Toyota Swaps
Sep 15, 2015 02:52 PM
94ofCanada
Aug 14, 2015 06:37 AM
norcal98
Aug 10, 2015 06:20 AM
landrunner
Aug 5, 2015 09:18 PM
