T4R first gen - Dashboard LED lights
Old Feb 24, 2019 | 09:33 AM
SomedayJ's Avatar
Hi guys!
I'm sure there're threads about this subject, anyway, if you're looking for LED lights for your 4R first gen dashboard, you'll need T5 fitting LEDs for the gauges and clinometer, and T10 fitting LEDs for the climate control faceplate and glove compartment.
Old Feb 24, 2019 | 11:24 AM
dropzone's Avatar
Fossilized
Looks awesome! Huge Improvement
Old Feb 24, 2019 | 03:21 PM
slacker's Avatar
looks great ! .. dash dimmer still work ?
Old Feb 24, 2019 | 10:27 PM
SomedayJ's Avatar
Thank you!
Thank you! No it doesn't work with these LEDs lights.
Old Feb 25, 2019 | 03:33 AM
wallytoo's Avatar
have you ever used yours? i have not, because the factory lighting is so weak, dimming it would serve no purpose.
Old Feb 25, 2019 | 05:28 AM
dropzone's Avatar
Fossilized
worked fine in my trekker..guess I got lucky
Originally Posted by SomedayJ
Thank you!
that is too bad. dimmer worked fine in both my 81 and 94 after converting the dash to LED's
Old Feb 25, 2019 | 05:59 AM
Discombobulated's Avatar
Odd, my 91’s dimmer doesn’t work either but my 87 Subaru GL dimmed perfect, maybe the older dimmers had a different way of changing the voltage along with your 94, doesn’t bother me much as I like my dash crisp at night. Although I went with green if I did a bright white it might be bothersome.
Old Feb 26, 2019 | 04:45 PM
slacker's Avatar
actually .. YES I do .. that would be why I asked !
SomedayJ
Feb 18, 2019 06:11 PM
carid
Vendor Advertising
Apr 16, 2015 12:51 AM
dropzone
Apr 1, 2014 08:28 PM
paynemw
12
May 21, 2012 09:40 PM
CDUFF7
Jul 7, 2008 05:00 AM
