symptoms: losing power on highway especially uphill smelling clutch too. cannot maint
Old Aug 26, 2009 | 06:42 AM
smelm0's Avatar
1991 yota p/u with 220k. 22re.
condition: compression readings- cyl. 1,2.3 = 170, cyl. 4= 160
afm replaced: ohms do rise as vane is opened from 200-almost 500. think oem is 200-1000
checked exhaust: not obstructed.replaced 1st of two 02 sensors
no check engine light showing
vacuum gauge: rapidly vibrating needle between 15 and 18. does not smooth out as throttle is opened which indicates worn valve guides. thinking maybe vacuum line open
somewhere.
clutch: can move truck starting in 3rd gear.
engine tuned at 800 rpms. 5btdc. plugs are all golden and dry. cap and rotor appear clean
needless to say, must get this baby up and running pronto. any and all help greatly appreciated. Mike
Old Aug 26, 2009 | 07:21 AM
Marc's Avatar
What does that mean?
Old Aug 26, 2009 | 07:38 AM
ScottyC's Avatar
Are you noticing the an rpm increase/race at all at those speeds. If so, then it needs a new clutch.
Old Aug 26, 2009 | 06:22 PM
smelm0's Avatar
no. actually, I'm noticing the opposite, that is, that the engine seems to be slowing down
Liadrin
Apr 25, 2022 02:54 PM
Sep 4, 2015 09:27 AM
Liadrin
Sep 1, 2015 06:44 AM
tj884Rdlx
Aug 28, 2015 12:04 PM
terminator
Jul 27, 2015 07:13 PM
