stumped by code 52.
Old 04-23-2015, 08:50 AM
Bigbsvo's Avatar
Does anyone know if its fixed?
I was reading the post because I have the same problem with a customers 4Runner. I was hoping the fix would be posted. It probably hasn't because it's probably not fixed like mine. Please post the fix if you do finally get that code to stay away. I need to know what to try next. I've about had it with this code.
Old 04-26-2015, 08:43 PM
AZSPEED's Avatar
If you check the wire at the ecu going to ks circuit and you show milivolts on your meter the ecu is the problem and seeing as how these ecu's are 20 plus years old it is most likely the problem. The capacitors on the ecu and the electrolytics go bad.the capacitor on the ecu is less than a dollar part replace it and all the other capacitors while your there and you sjould be good. Have not seen one yet that it didn't fix.
some drunk guy
08-03-2021 06:09 PM
moparbay
10-06-2015 09:24 AM
Odin
09-26-2015 06:56 PM
Draven023
09-26-2015 12:41 PM
AkitaDog
09-03-2015 09:01 PM
Quick Reply: stumped by code 52.
