Stuck in 4 Wheel Drive
Old Jan 28, 2010 | 07:32 AM
cjlqtr's Avatar
I recently acquired a 95 4WD pickup with 22RE, 5 speed manual trans, and manual locking hubs. I used the 4 WD for the first time today but can't get it back into 2WD. Tranfer case shifted right into 4WD and goes easily between 4WD High and Low but I can't move the shifter back into 2WD. Tried it with truck stopped, in neutral, and clutch depressed. Any ideas??
Old Jan 28, 2010 | 07:54 AM
fishon1213's Avatar
Put the truck in reverse and try.
Old Jan 28, 2010 | 07:58 AM
kawasakimoto_7's Avatar
yeah roll back in reverse, my 95 does the same thing every single time.
Old Jan 28, 2010 | 10:14 AM
cjlqtr's Avatar
Thanks. I rocked the truck a little previously with no luck but after backing up 20-30 feet it shifted easily into 2WD.
Old Jan 28, 2010 | 10:24 AM
4Crawler's Avatar
Perfectly normal, result of drive line binding in 4WD. What I try and do is shift out of 4WD before hitting a high traction surface and while moving straight ahead without any recent turns. This way you shift out of 4WD before the drive lines and transfer case get bound up.
Old Jan 28, 2010 | 11:34 AM
yoder519's Avatar
happens in both my 85 and 95, ive found backing up and goin forward fixes it like stated above
Jun 1, 2021 01:51 PM
hexrain
Jul 12, 2015 01:13 PM
Poncho0206
Jul 10, 2015 06:21 PM
Yotoder865
Jul 9, 2015 07:51 PM
skoti89
Jul 6, 2015 07:45 PM
