strange idle after valve cover gasket replacment
Old Jan 27, 2011 | 04:55 PM
OL' YELLA's Avatar
today i changed my valve cover gasket and cleaned my throttle body with throttle body cleaner. on my 93 22re and now its got a strange idle i some times it will idle high like at 1200 rpms and other times it will idle low at like 500 rpms . and when i drive it sometimes if i take off on it and put it in the floor it wants to bogg down and sputter then i got to back off and ease into it . it ran fine before i did these things this morrring any ideas what may be going on with my truck .
Old Jan 27, 2011 | 04:59 PM
SoCal4Running's Avatar
Check the TPS wire, could of come undone.
Old Jan 27, 2011 | 05:19 PM
OL' YELLA's Avatar
its pluged in im thinkin it may just need a good seafoam of the intake and injectors
Old Jan 27, 2011 | 05:58 PM
peckinpah's Avatar
Do you have both of the half moon seals on the valve cover seated properly? Hopefully you unplugged the tps before cleaning the throttle body? If not, you may have ruined it and that's why your idle is acting up.
One of the times I took off my valve cover, I broke off the piece of plastic where a couple of vacuum hoses attach, causing a vacuum leak. That might be another possibility, especially if you're a clumsy mechanic like I am.
Old Jan 27, 2011 | 06:06 PM
OL' YELLA's Avatar
the half moon seals are seated right no oil leaks but i havent checked for vacuum leaks
Old Jan 28, 2011 | 01:31 PM
rpij137g's Avatar
check your fuel injectors.
Old Jan 28, 2011 | 03:55 PM
OL' YELLA's Avatar
turns out my spring on my throttle body is wore out and not closing the butterfly valve all the way hooked another spring to it and sloved the problem
Old Jan 30, 2011 | 05:13 AM
rpij137g's Avatar
nice !
jennygirl
Nov 17, 2015 11:24 AM
fasterspider
Oct 6, 2015 10:24 AM
Ichneumon
Sep 27, 2015 04:21 PM
puddlepirate
Jun 30, 2015 05:08 PM
serenity03k64
Jun 27, 2015 07:59 AM
