steering leak with smoke?!
Old Jan 12, 2008 | 10:03 AM
cootees's Avatar
So here is the run down. 90 4runner with the 3.0 The steering fluid reservoir goes dry within minutes of filling it and every time I fill the thing white smoke starts pouring out of my tail pipe.. kind of like when you get water in your engine.
I don't see it leaking anywhere its almost as if the fluid gets sucked into the engine.. anyone have any ideas?
Old Jan 12, 2008 | 10:15 AM
toytech76's Avatar
I know exactly where its going. We had one doing the same thing. There is a idle up valve attached to the bottom of the pump that has 2 vac lines going to it. It raises the idle of the eng when you turn the wheel at idle. The valve has gone bad inside and allowing fluid to be sucked into the eng via those vac lines. replace the valve and your problem will be solved
Old Jan 12, 2008 | 07:40 PM
mr toytech's Avatar
x2, ive seen it many times.
Old Jan 12, 2008 | 07:43 PM
cootees's Avatar
ok, thanks guys. the idle-up valve is the same as the iac valve?
Old Jan 12, 2008 | 07:45 PM
mr toytech's Avatar
no. this valve is on the bottom of the power steering pump.
Old Jan 12, 2008 | 07:48 PM
drew303's Avatar
Take it off and plug it w/ matching bolt and RTV .. cap the vac lines on the plenum. you dont need this valve IMO.
Old Jan 13, 2008 | 07:35 AM
cootees's Avatar
ok, found it. Here is a pic for anyone else that mayrun into this problem later down the road.
I'm going to try capping it off for now and I can always change it later on if I need to.
Up&Down
Aug 11, 2015 10:04 AM
gillesdetrail
Aug 3, 2015 04:43 PM
gmonnie123
Jul 26, 2015 02:44 PM
Jonny246
Jul 24, 2015 12:37 PM
Coreyr384
Jul 10, 2015 11:13 AM
